DonutBridgeBuilder in SDE (Potential Bug?)
  • May 16, 2018 6:14 PM UTC
  • 7 replies
  • 81 views
DonutBridgeBuilder transformer works fine when output is a file geodatabase but it does not create correct polygons when output is a feature class in the enterprise geodatabase. Any idea?
@Azin Would you be able to include a sample dataset and workspace that illustrates the problem when writing to File Geodb and Enterprose Geodb?
  • May 23, 2018 4:53 AM UTC
I have attached a sample dataset (FGDB) with FME work-space. If you store the output in SDE the result is not correct. fme-donut.zip
  • May 23, 2018 5:48 PM UTC
@MarkAtSafe I attached the dataset sample.
  • May 23, 2018 9:22 PM UTC
The attached screenshots show how the output looks like in FGDB and EGDB.
Output in Enterprise GeoDB:
Output in FGDB ( which I need):
fmelizard
Forum|alt.badge.img+22
  • May 23, 2018 10:54 PM UTC
Hi @Azin What error are you getting when writing to GEODATABASE_SDE? Please file a case via https://www.safe.com/support/report-a-problem/ and include a workspace with the GEODATABASE_FILE writer as well as the log file. Thanks!
  • May 23, 2018 11:19 PM UTC
Hi @DanAtSafe
The FME job doesn't return error in log but the output (in SDE) is not correct. It doesn't build connections between donuts.
fmelizard
  • May 25, 2018 7:04 AM UTC
Hi @DanAtSafe
Hi @Azin I've confirmed the problem. The "bridges" are lost when writing to GEODATABASE_SDE, but not GEODATABASE_FILE. Please file a case at https://www.safe.com/support/report-a-problem Thanks
