Does the FME installer produce a log file?
  • Dec 5, 2016 8:07 PM UTC
  • 7 replies
  • 101 views
fmelizard
Forum|alt.badge.img+22
I'm trying to install FME but I am getting errors. If there was a log file, it might be helpful to identify what is going on!
Keywords: desktop install log server install log command line install
Best answer by andreaatsafe
I'm pleased to announce that an installation log file is automatically created when installing FME 2021.0 and newer when using the Setup.exe after extracting the files.
rylanatsafe
Forum|alt.badge.img+14
You can run the FME installer using the command line and specify that it log out to a text file.
Use the following command inside a Command Prompt as Administrator, with the appropriate FME installer filename:
msiexec /i fme-desktop-b15573-win-x86.msi /l*v log.txt
fmelizard
  • Mar 14, 2017 5:49 PM UTC
The same applies for FME Server:
msiexec /i fme-server-b19999-win-128.msi /l*v log.txt
erik_jan
Forum|alt.badge.img+26
  • Mar 14, 2017 5:54 PM UTC
Would be great if this was an option in the installer wizzard, or the default setting.
I don't see many of my customers using a command line like that.
itay
Forum|alt.badge.img+19
  • Mar 14, 2017 7:09 PM UTC
you have my vote for this idea....
erik_jan
  • Mar 14, 2017 7:20 PM UTC
Done: https://knowledge.safe.com/idea/41291/installation-log.html
itay
  • Mar 14, 2017 8:40 PM UTC
andreaatsafe
Forum|alt.badge.img+17
  • Mar 16, 2021 11:44 PM UTC
