Does ISO format in TimeStamper is in UTC format?
  • Apr 26, 2024 3:37 PM UTC
  • 76 views
marias
Forum|alt.badge.img+11
In case I select ISO format in TimeStamper, does it assume that it is UTC or not nesessarily?
How to set it to UTC?
jkr_wrk
Forum|alt.badge.img+37
  • Apr 28, 2024 10:26 AM UTC
Have you ever tried to update your transformers?
Had to search around to find the existance of a TimeStamper transformer. It's currently called DateTimeStamper and has more clear settings about the Timezone.
I could find help on the Timestamper in the 2016 version of FME and not in the 2017.
DanAtSafe
Forum|alt.badge.img+23
  • Apr 29, 2024 6:31 PM UTC
Hi @marias The DateTimeStamper has defaulted to UTC since FME 2020. I don’t have anything older than 2019 installed locally but that also has the option of setting the time stamp in UTC.
