Does anyone know how to generate a map with FME, I met a resolution issue when creating base map. The wms link looks good in QGIS, but when use FeatureReader in FME, use bbox to get the wanted are, the resolution is super low.
  • Sep 28, 2023 12:30 PM UTC
  • 81 views
Forum|alt.badge.img+63
What have you set for the Map Height and Map Width parameters on the WMS reader?
  • Sep 28, 2023 2:56 PM UTC
I tried with the bbox which is also the map area's width and height, but the resolution didn't change
The values you enter there are the pixel size of the result you're getting back, so depending on the units of the data and the native resolution of the underlying raster data using the bounding box size will not yield a high-res result.
Try changing them and see what happens.
  • Sep 29, 2023 10:57 AM UTC
Thanks for the reply!
