Do not convert DWG to GeoTIFF
  • Aug 20, 2021 7:38 AM UTC
  • 115 views
I have a *DWG file. I want to convert it to GeoTIFF. I used tool from link: https://hub.safe.com/publishers/safe-lab/templates/converting-vector-data-to-raster#description.
Even though it exports successfully, I don't see the GeoTIFF output.
What step am I doing wrong?
Please tell me. Thanks
20-08-2021 14-33-49
caracadrian
Forum|alt.badge.img+23
  • Aug 20, 2021 8:48 AM UTC
The log file says 0 (zero) features output.
The example here is very old and I think it was flawed to begin with:
  • DonutBuilder should be set to Drop Holes = Yes
  • tile_boundary in buffered with an interpolation angle of 0 - should have a float grater than 0 (put 0.01)
  • 2DEllipseReplacer on elevations dataset has to create a circle (primary and secondary axis are set to 1) in a LatLong system that is reprojected somewhere down the line. A circle with the radius of 1 degree (as in measurement of arc distance not angle) is of greater area than all other features present in the workspace (put 0.0001) - You should never create circles in a LatLong coordinate system, reproject first...
  • Rasterizer1 should have a specified PATH (maybe the setting worked in 2011 but 10 years of development changes things), just browse to a folder that you want the tiff to be exported to and click OK.
