Dissolver issue
  • Aug 2, 2019 12:29 PM UTC
  • 89 views
Forum|alt.badge.img+54
I'm having an issue with unexpected results in the dissolver
The geometry is validated prior to dissolving but there's a reasonable likelihood of a duff input polygon possibly arc(the shape not the program) related. If i put polygon with count 13 only through an ArcStroker and then dissolve with the rest the output is as expected. But i've not found a way to highlight that this polygon is the problem.
I've attached a template file if anyone wants to take a look, I'm still using 2018 so perhaps this doesn't occur in 2019...
Best answer by takashi
The Dissolver in 2019 is much better than before on both accuracy and performance.
  • Aug 2, 2019 12:49 PM UTC
fmelizard
Forum|alt.badge.img+22
  • Aug 9, 2019 5:11 AM UTC
The FME 2019 Dissolver brings us much joy. Hope @egomm is able to upgrade... (and sorry we didn't get this solved sooner, but trust us, this is a hard hard problem...)
  • Aug 9, 2019 8:26 PM UTC
No opportunity to upgrade currently but found a workaround :-)
