Dissolve line by attribute
  • July 28, 2014
  • 379 views
jon
Forum|alt.badge.img+5
So I thought this would be easy to do in FME but I've had to revert to ArcToolbox to perform one step prior to running my workbench.  I need to dissolve a street feature class based on an attribute (street_name_id) and keep a few attributes (first record).
Here are the settings I use in ArcToolbox - how do I reproduce this in FME?
Best answer by takashi
HI,
Yes, the LineJoiner corresponds to ArcGIS Dissolver tool (Unsplit Lines) for line geometries. But the Dissolver tool (Create Multipart) creates multi-part line. If you need to create multi-part line, consider using the Aggregator.
Takashi
  • July 29, 2014
HI,
Takashi
