Network Analysis Tracing Downstream with Multiple Source
  • Jun 6, 2025 2:25 PM UTC
  • 5 replies
  • 322 views
elmido13
Forum|alt.badge.img+4
How to trace downstream in the network with multiple sources and accumulate the value from the intersected nodes of each trace? To Illustrate please see below. Black circles are the starting points.
Appreciate your help.
Best answer by takashi
Hi ​@elmido13 ,
I think you can use NetworkCostCalculator to achieve the goal in this case. The process would be a bit long story, see the attached workspace example to learn more.
crutledge
Forum|alt.badge.img+55
  • Jun 6, 2025 11:36 PM UTC
Hi ​@elmido13
In my mind I would want to say there must be some way to set this up. For each point dissolve all lines downstream of the point, then use that dissolved line to select all points along and then do the calculation. Buuuut, for actual tracing tools I think ​@j.botterill covered it with his answer a little while ago.
  • Jun 7, 2025 8:26 PM UTC
Hi ​@elmido13 ,
elmido13
  • Jun 12, 2025 8:56 AM UTC
​@takashi Thank you for your assistance. I truly appreciate it. I will review the WB and learn from it. I’ll let you know whether this addresses the issue discussed here.
elmido13
  • Jun 12, 2025 8:58 AM UTC
​@crutledge Thank you for insight. I truly appreciate it.
elmido13
  • Jun 28, 2025 9:39 AM UTC
​@takashi the example you give me. Help solve my problem. Thank you so much. Really appreciate the help.
