Dissolve adjacent polygons along multiple tiles
  • Mar 24, 2019 10:53 PM UTC
  • 17 replies
  • 264 views
jorge_rosales
Forum|alt.badge.img+8
I describe an example or a general problem. I have six files (tiles), each one with one o more polygons that have their own (file local) id. As showed in this picture.
No common attributes values exists for each whole polygon so a grouped dissolver would not be a solution. The grid geometry (cutter) is known. The desired result would be:
Any suggestion?
Best answer by ebygomm
Use a spatial relator to find features that touch but have a different filename, assign a group to these features then use that group to dissolve
dissolve_different_tiles.fmwt
Although i think this sort of area will still be problematic
danilo_fme
Forum|alt.badge.img+58
  • Mar 24, 2019 11:45 PM UTC
Hi @j4
The transformer Dissolver did'nt work?
Thanks,
Danilo
jorge_rosales
  • Mar 24, 2019 11:52 PM UTC
Hi @j4
Thanks,
Danilo
Dissolver removes common boundaries so the three polygons in the bottom right corner will be merged into one instead three.
danilo_fme
  • Mar 25, 2019 12:03 AM UTC
Thanks your reply.
Could you share a amount of data?
Thanks
jorge_rosales
  • Mar 25, 2019 1:17 AM UTC
Thanks your reply.
Thanks
@danilo_fme a geopackage is attached.
test_data.zip
Forum|alt.badge.img+54
  • Mar 25, 2019 8:03 AM UTC
jorge_rosales
  • Mar 25, 2019 10:25 AM UTC
@egomm "touches" predicate mixes "point touches" and "line touches" so the feature set associated to one feature will be oversized. "Touches" is also a binary operator and there are features along multiples files (as the rotated L-shape one).
  • Mar 25, 2019 10:27 AM UTC
You can use a spatial predicate instead of touches to ignore polygons that only touch at the corners. (Although this would only be a problem if the corner also coincided with a tile boundary) The features over multiple files is handled by the list combiner
jorge_rosales
  • Mar 25, 2019 10:32 AM UTC
Ok, it could be a solution. Any suggestion for long polygons in multiple (more than 3) files?
  • Mar 25, 2019 10:38 AM UTC
Have you tried the attached fme template file?
It should produce this output from your input data
jorge_rosales
  • Mar 25, 2019 11:22 AM UTC
Ok, this is what I need. Thank you very much @egomm.
gio
Forum|alt.badge.img+15
  • Mar 25, 2019 5:26 PM UTC
@j4
Post_Tiler_Rebuild_out.fmwt
The problem Is of course the lacking information. THis should have not been removed after tiling.
One should always preserve the object ID as wel as the row and column values.
The dataset you provided shows the problem.
You end up with a forced iterative process which not nescesarrily has a solution.
Create lists of the touching polygons, query the list with and a bunch of the objects get re-united. But polygons split over more than one tile pose a problem. There is no way to identify which should be merged.
I embed a workbench, that does 1 pass. I found no way to coherently iterate and dissolve the objects cut by borders.
You might want to see how you can "dissolve" without dissolver.
jorge_rosales
  • Mar 25, 2019 7:22 PM UTC
@j4
@gio the solution pointed out by @egomm seems to work. Try the attachment.
listcombiner.fmwt
gio
  • Mar 26, 2019 2:17 PM UTC
@j4
I get it that it "works".
I also say that one does not actually knows (unless one has prior knowledge) whether polygons which touch on a border or borders should be dissolved.
Whether those objects were once a single object.
SO it seems like gambling on assumptions.
jorge_rosales
  • Mar 26, 2019 4:58 PM UTC
@j4
I agree. In this particular case the initial dataset could be seen as the result of a "Clipper" using a known grid. Maybe FME could have an "UnClipper" transformer that receives the clipped features (clipped input port) and the geometry used as clippers (clipper input port).
  • Mar 26, 2019 5:03 PM UTC
That option still wouldn't solve the issue that gio is concerned about, although I think looking at your input data it's unlikely to be an issue.
But if you have the scenario where two adjacent features have their shared boundary falling exactly on the grid line, they would be dissolved together in error.
jorge_rosales
  • Mar 26, 2019 5:12 PM UTC
Yes, that is true.
@j4 If you can, I would try running your workflow in FME 2019. We have done a lot to improve both the performance and the results of the dissolve. Our testing shows that the 2019 Dissolver is between 2 to 76 times faster, depending on the input data.
You can have multiple versions of FME desktop installed, just use a different install folder, i.e. c:\\apps\\fme2019. You can find FME 2019 betas here.
