Disable multiple Inspectors at once
  • May 14, 2015 12:38 PM UTC
  • 60 views
I have a large workbench with about 10 custom transformers and almost 50 inspectors.
There are times when I want the workbench to run with all the inspectors disabled and times when I want them all enabled.  But the only way I can find to disable and enable them is turn do it manually one-by-one in the Navigator window and this takes a lot of time.
Does anyone know a way that I can enable/disable all Inspectors in the workbench and across the Custom Transformers, at once?
Thanks,
pratap
Forum|alt.badge.img+12
  • May 15, 2015 8:21 AM UTC
If you want to turn off inspectors before execution of workbench then use "Enable/Diable Transformers" in transformers menu...
If you want to turn off inspectors in custom transformers then
Use "Tester" before inspector and and divert the flow...
Plaese the condition in the tester equal to some published parameter such that it will be dependent on the input you provide.
Hope this will help...
Pratap
  • May 15, 2015 10:27 AM UTC
Hi Pratap
Thanks yes both those solutions work for me :)
