I just upgraded FME Form and FME Flow from 2024.0 to 2024.2.3.
One of my jobs failed using a FeatureReader with the Directory and File Pathnames due to the extension not being in all caps because the extension on the file it’s looking for is in all caps (.CSV). Originally the parameter was set to filename.csv and the FeatureReader would have no issues finding the file on 2024.0. Now the FeatureReader is not able to find the file in 2024.2.3. I changed the parameter to all caps .CSV in the featureReader and it finds the file with no issue.
Anyone else noticing this with 2024.2.3?
