Difference between 2 datasets - Delta
  • May 21, 2013
  • 35 views
What would be the best set of transformers to report on 2 non spatial (CSV) datasets A versus B.
I am trying to report deleted records from A because they are not in B, new records in B because they are not in A and attribute differences between A and B reporting B's attributes.
I thought this would have been simple with a FeatureMerger or 2 but alas, it escapes me.
  • May 21, 2013
take a look at the ChangeDetector or the UpdateDetector (from the FME Store).
David
fmelizard
Forum|alt.badge.img+22
  • May 21, 2013
David's direction is correct, but for the first 2 comparisons you could just use the feature merger.
Itay
