DGN to GDB is causing issues.
  • Jun 22, 2023 3:46 PM UTC
  • 0 replies
  • 31 views
 I have tried both attribute checker and attribute manager to pull the data from the dgn and then run it into geometry filter to place it into an existing gdb, and this does not seem to be the correct workflow. Is there a standard setup for converting a DGN to a GDB?
