Determine in-between alphabetic values
  • Sep 13, 2018 2:08 PM UTC
  • 91 views
westerbrink
Forum|alt.badge.img+4
I've got a table with POSTCODE_FROM and a POSTCODE_TO attributes, constituting several alphanumeric ranges, for example:
(from) 7887AA (to) 7887AA
(from) 7887AB (to) 7887AC
(from) 7887AD (to) 7887AJ
(from) 7887AK (to) 7887BB
Each feature has a FROM and a TO value and I would like to determine all in-between values, e.g. 7887AE, 7887AF, 7887AG, 7887AH, 7887AI.
Does anyone know what (sequences of) transformers are capable of doing this?
Best answer by ebygomm
It's a bit convoluted if you don't want to resort to python
postcode-from-to.fmw
  • Sep 13, 2018 2:52 PM UTC
Try the following in a PythonCaller, it will clone the incoming feature for each possible variant between POSTCODE_FROM and POSTCODE_TO:
from fmeobjects import *
import string
digs = string.digits + string.ascii_uppercase
def int2base(x, base):
    # Shamelessly stolen from https://stackoverflow.com/a/2267446
    if x < 0:
        sign = -1
    elif x == 0:
        return digs[0]
    else:
        sign = 1
    x *= sign
    digits = []
    while x:
        digits.append(digs[int(x % base)])
        x = int(x / base)
    if sign < 0:
        digits.append('-')
    digits.reverse()
    return ''.join(digits)
class StringIterator():
    def input(self, feature):
        str_from = feature.getAttribute('POSTCODE_FROM')
        str_to = feature.getAttribute('POSTCODE_TO')
        int_from = int(str_from, len(digs))
        int_to = int(str_to, len(digs))
        for x in range(int_from, int_to+1):
            f = feature.clone()
            f.setAttribute('POSTCODE', int2base(x, len(digs)))
            self.pyoutput(f)
Set "Class or function to process features" to "StringIterator", then expose the attribute "POSTCODE"'.
Sample result for a single feature entering with (from) 7887AD (to) 7887AJ:
Forum|alt.badge.img+54
  • Sep 13, 2018 7:54 PM UTC
  • Sep 14, 2018 2:05 PM UTC
I tried this with the InlineQuerier.
SQL Query:
select a.*, b."POSTCODE"
from ranges as a
inner join postcodes as b
on b."POSTCODE" between a."POSTCODE_FROM" and a."POSTCODE_TO"
westerbrink
  • Nov 21, 2018 1:19 PM UTC
This method is most useful to me. Thanks a LOT!
