Deleting polygons witch have the same coordinates (duplicates)
  • Apr 1, 2013 2:29 PM UTC
  • 5 replies
  • 85 views
robertr
Hello,
I was wondering if this can be done with an operator? Many times, I see polygon shapefiles which have a feature duplicated even 1,000 times (same coordinates).
Let's say that I need a clean shapefile, and I want to get rid of the polygons which are duplicated several times (i am not interested in the attributes..even if they are different for the same geometry, I want to delete them and keep only one)
Is this possible?
robertr
  • Apr 1, 2013 2:33 PM UTC
Oh my God. I meant which*** not witch! Why can't we edit our post? I cannot understand any reason for this. At least a time frame of 10 minutes for editinf reasons...
Sorry all!
fmelizard
Forum|alt.badge.img+22
  • Apr 1, 2013 2:50 PM UTC
There are several ways to do it, I would calculate a CRC on the geometry and test for unique CRC values.
Hope this helps.
fmelizard
  • Apr 1, 2013 6:04 PM UTC
btw for testing unique CRC values I would use the duplicate remover.
  • Apr 1, 2013 6:14 PM UTC
Hi Robert,
have you looked at the Matcher? It will allow you to find matching features based on matching geometry, matching attributes, or both.
If you already have a license for the MRFCleaner transformers (or have a budget for it), the MRF2DCleaner will do the same thing, but with a lot more options and functionality. Very handy in some instances.
If you want to persue the solution proposed by Itay, take a look at the CRCCalculator. Just be aware that this solution will not give you any leeway in regards of tolerances, though.
David
robertr
  • Apr 2, 2013 4:54 AM UTC
Hello,
Thank you all for the assistance!
