Delete jpeg files in folder outside a polygon
I have a folder with jpeg images and a txt with latitude and longitude for each image name.
I would like to delete all files in the folder, that are located outside a polygon.
Can somebody help me getting started? (e.g. How to delete files in a folder, ...)
Best,
J.
  • March 11, 2015
you could use a SpatialFilter to isolate the jpegs that are outside your polygon. Then send them to a PythonCaller for deletion:
import os
import fmeobjects
def FeatureProcessor(feature):
    os.remove(feature.getAttribute('fme_dataset'))
David
  • March 16, 2015
Thank you David!
