DateTimeNow not working on MacOSx
  • Jun 7, 2018 2:27 AM UTC
  • 5 replies
  • 109 views
philippeb
Forum|alt.badge.img+23
I'm trying to run a workbench on my MacOSx 10.13 using DateTimeNow function but I get this error :
AttributeCreator: Failed to load timezone data. Please visit http://www.safe.com/support
AttributeCreator: Failed to evaluate expression '@DateTimeNow()'.  Result is set to null.
It runs perfectly on Windows 7.
Do you know what could cause that? I've check into my options and my time zone is defined.
Best answer by fmelizard
Hi @philippeb and @redgeographics. Unfortunately @philippeb you have encountered a known issue (PR# 80324) which has been resolved in FME 2017.1.2 builds 17714+ and FME 2018.0 builds 18204+. Would you be able to upgrade to either 2017.1.2 or 2018.0 to verify that the fix works for you?
FME 2017.1.2.1 is available from https://www.safe.com/support/support-resources/fme-downloads/archived/
FME 2018 is available from: https://www.safe.com/support/support-resources/fme-downloads/
How to install multiple versions of FME on the same machine: https://knowledge.safe.com/articles/796/installing-multiple-versions-of-fme.html
My apologies for any inconvenience this may cause.
Kind regards,
Natalie
Forum|alt.badge.img+63
That's odd, I'm on OSX 10.12 and it works fine there.
Can you try a DateTimeStamper instead?
philippeb
  • Jun 7, 2018 12:47 PM UTC
Yeah I tried a DateTimeStamper into a new blank workbench but this transformer is using the DateTimeNow function so it isn't changing anything.
I have FME 2017.1 btw. And you?
I kinda feared that it would use the same function. @NatalieAtSafe, could you get somebody to look at this please?
fmelizard
Forum|alt.badge.img+22
  • Jun 7, 2018 4:22 PM UTC
Kind regards,
Natalie
philippeb
  • Jun 8, 2018 3:04 AM UTC
Kind regards,
Natalie
Thanks Nat! I'll update my version.
