Dates in charts
  • Nov 1, 2023 4:42 PM UTC
  • 112 views
paul_c_2
I have yet to successfully use dates as an axis in ChartGenerator. Ideally, I would like to be able to use more natural date formats e.g. %B %Y or %m %Y and set the scale accordingly based upon time increments. Is this possible (in Chart Generator or another transformer) ? Or am I going to need to take it out into PowerBI, Excel, etc?
danilo_fme
Forum|alt.badge.img+58
  • Nov 2, 2023 11:00 AM UTC
Hi @paul_c_2​
Please, could you share a example of your data?
Thanks in Advance,
Danilo
paul_c_2
  • Nov 6, 2023 12:16 PM UTC
Absolutely!
mlufkin
Forum|alt.badge.img+11
  • Nov 10, 2023 3:10 PM UTC
Hi @paul_c_2​,
I've had this issue before too - the workaround for me has worked in the past is this:
  • Create additional features to 'fill the gaps' of any missing months (i.e. if you have months 202301, 202303 and 202304, create 202302) to give your chart a fighting chance of having consistent distances between months) - in this case not needed.
  • Sort by Month, to order your features correctly. They need to stay in the correct order for the ChartGenerator
  • Use Attribute Manager/Creator to add '01' to the Month (so that the DateTimeConverter will work)
  • DateTimeConverter to convert this date into '%B %Y'
  • Plot values in ChartGenerator
Capture5
All the best,
Martyn
paul_c_2
  • Nov 10, 2023 3:13 PM UTC
Hi @paul_c_2​,
Capture5
All the best,
Martyn
awesome, will give it a go! Merci
