Date Range Query
  • Nov 2, 2016 1:26 PM UTC
  • 10 replies
  • 474 views
I have looked at "Date Range Tester" and "Date Constraint" topics that are related to this.
I have a workspace that pulls in a non sql table. I want to be able to query this table to look for data within a date range. I created two published parameters - Start Date (11/04/2004) and End Date (11/18/2004). The work space is set to run with prompts so that the operator has to enter these two dates.
The Date Range Tester semi-works. I am getting some strange results though. My date attribute is a string as such (20041104000000.000). I trim off the empty "Time" part of the string leaving only the "Date" (20041104). I use a Tester to test for a range between 20041104 (Lower Limit, Greater than or equal to valve) and 20041118 (Upper Limit, Less than or equal to value). In the results I am getting results between 20041103 - 20041118. I don't understand why I am getting these.
Please advise if there is another option to extract this information. Any help is much appreciated.
itay
Forum|alt.badge.img+19
  • Nov 2, 2016 1:31 PM UTC
Hi @jimq66 I would suggest doing this querying on the table itself, this way you can efficiently get ONLY the records you need in your workspace.
Another advantage is that you dont need to deal with different date definitions in your testing.
  • Nov 2, 2016 2:02 PM UTC
Hi @jimq66, I was able to reproduce the same result as yours. The Tester in FME 2016.1.2.1 build 16674 outputs a feature having "20041103" via the Passed port with this setting. I think it's a bug in the "In range" operator. @daleatsafe, please take a look.
In the interim, try this setting instead.
  • Nov 2, 2016 2:10 PM UTC
This test clause routes "20041105" to the Failed port. We cannot use the "In range" operator.
Forum|alt.badge.img+54
  • Nov 2, 2016 2:19 PM UTC
You could also use an AttributeRangeFilter to perform the test
  • Nov 2, 2016 2:29 PM UTC
I was working on this and it just might work. @takashi solution was quick and works. I still use my parameters.
  • Nov 2, 2016 2:30 PM UTC
Don't see a way to use the published parameters here. Am I missing something. Thanks.
  • Nov 2, 2016 4:03 PM UTC
Hi @takashi Is there a way to convert the input of the published parameters from this format input (11/04/2004) to this format output (20041104)?
  • Nov 2, 2016 4:20 PM UTC
once save the parameter value into an feature attribute using the ParameterFeatcher or AttributeCreator, and then convert the attribute value into the required format with the DateFormatter transformer.
fmelizard
Forum|alt.badge.img+22
  • Nov 3, 2016 3:01 PM UTC
THanks for alerting us @takashi -- the team has found that there defnitely is a bug here and we're examining ways to fix it. We'll keep this thread posted.
  • Nov 9, 2016 2:34 AM UTC
It seems that the bug about the "In range" operator has been fixed in FME 2016.1.3.0 release build 16709.
