Date functions only available in featureWriter transformer not in a Writer, why?
so_much_more
I need to write datetime to a comment on a SQL table after my postgres SQL writer is complete.
This can easily be done like when using a featureWriter like so:
COMMENT ON SCHEMA "my schema" IS '@DateTimeFormat(@DateTimeNow(), %Y-%m-%d %H:%M)';
This is not possible if i use a regular postgres writer. Only SQL functions are available. This alone is not enough to set a timestamp.
Tiny but frustrating neuance between almost identical transformer/writers. What other ways can i inject a datetime into my comment on schema syntax?
Best answer by bwn
Hmmm, been years since had a PostGreSQL instance to design on.
Alright well this is a hack to create a dynamic string literal using FORMAT() and give a value formatted to a string literal with the %L format flag.
FME_SQL_DELIMITER ;
DO $$
BEGIN
    EXECUTE FORMAT('COMMENT ON SCHEMA “my schema” IS %L', TO_CHAR(CURRENT_TIMESTAMP, 'YYYY-MM-DD HH:MM'));
END $$ LANGUAGE PLPGSQL;
hkingsbury
Forum|alt.badge.img+53
  • October 1, 2024
@ctredinnick will be able to help with this :)
bwn
Forum|alt.badge.img+26
  • October 2, 2024
Why not use instead:
COMMENT ON SCHEMA "my schema" IS LOCALTIMESTAMP(0);
Or if really want the current datetime truncated to current minute
COMMENT ON SCHEMA "my schema" IS DATE_TRUNC(‘minute’,LOCALTIMESTAMP());
so_much_more
  • October 2, 2024
I tried both examples (and other similar examples)
postgres throw an error using anything other than pure strings when setting commets. Thats why i need to use FME functions to inject the string directly into the SQL.
 syntax error at or near "DATE_TRUNC"
bwn
  • October 2, 2024
FME_SQL_DELIMITER ;
DO $$
BEGIN
so_much_more
  • October 8, 2024
FME_SQL_DELIMITER ;
DO $$
BEGIN
Thanks that worked! Thank you for the help :)
