Date format conversion Unix
boubcher
Forum|alt.badge.img+11
Hello there
Traying to use FME to convert date format
date : 1591982226
conversion :Friday, June 12, 2020 5:17:06pm
the conversion was done using this tool ( https://www.silisoftware.com/tools/date.php?inputdate=1591982226&inputformat=unix )
is there a way we get the same result with FME transformer
Thanks
Best answer by itay
This looks like a job for the DateTimeConverter transformer and the date value looks suspiciously like epoch, so using %s as your input date should to the trick.
Hope this helps.
itay
Forum|alt.badge.img+17
  • June 12, 2020
Hope this helps.
boubcher
  • June 13, 2020
itay wrote:
Hope this helps.
@itay
THanks working
