Dataset Fanout in 2025.2
  • Mar 17, 2026 11:54 AM UTC
  • 85 views
edmund.har
Forum|alt.badge.img+4
Hi all,
I am experiencing an issue with dataset fanout in my workbench after upgrading to 2025.2.0.0 with Build 25810 (WIN64). The workbench worked perfectly in 2024.2.
The workbench reads in a FGDB file 30,000,000 features using a reader, then performs spatial filtering with coordinate grid tiles and fanout into geopackage files according to the tile names using a writer. The workbench always stopped while outputting the first geopackage file with the following error message.
Insufficient memory available -- error code was 2 - please read the FME Help section 'Adjusting Memory Resources' for workarounds.
The workbench worked fine when I set the max features to read in the reader as 100,000, but the writer failed once the reader read all 30,000,000 features. I tried lowering the number of features per transaction in the writer but it did not work.
Is anyone else experiencing a similar memory issue with dataset fanout in 2025.2?
Thank you for your help in advance.
nordpil
Forum|alt.badge.img+13
  • Mar 17, 2026 12:08 PM UTC
Are there any blocking transformers in the workspace? Just wondering if it needs to hold 30 mill features in memory...
edmund.har
  • Mar 17, 2026 12:14 PM UTC
Hi ​@nordpil I assume the SpatialFilter holds all features before starting dataset fanout to individual geopackage files.
nordpil
  • Mar 17, 2026 12:24 PM UTC
I don’t think so, but that is easy to test when you run it interactively. But you need to make sure that the filter(s) are loaded before any candidates. I think you could also consider, instead of filtering, reading based on the geometry queries (the tiles) using FeatureReader(s).
