data inspector will not launch from workbench
  • Jan 22, 2019 10:23 AM UTC
  • 5 replies
  • 106 views
Hi, After the last windows update (windows 10 pro 1803) data inspector will not launch from workbench. This normally occur when data inspector is running in the background. But not this time. Its also possible to open data inspector from start menu.
Anyone else having the same experience?
Forum|alt.badge.img+63
That doesn't look familiar. Have you tried reinstalling FME?
  • Jan 22, 2019 11:13 AM UTC
Yes, In different paths as well
Actually... now that I think about it more, it does sound familiar: https://knowledge.safe.com/questions/73001/data-inspector-doesnt-open-up-automatically-anymor.html
If you're not using the build that's mentioned there (18552) could you try it with that one. If that doesn't solve it it's probably a good idea to contact Safe's support as @Nampreet mentioned.
  • Jan 22, 2019 2:01 PM UTC
I have found out what causes it. And this applies for all my workbenches.
If I paste the workbench into a blank workbench, it launches the inspector without any problem. If I save and run it again, the inspector will not run. Strange..
That is really strange indeed. I think it'd be a good idea if you report this to Safe's support people.
