Dangle line
Hy Guys
I need to identify and remove dangle geo of a netw
To be clear I need to remove all blue geo in the bmp attached.
I tried some workaround with coordinates but no success
Francesco
  • March 16, 2018
  • March 16, 2018
HY
I tried but no succes
thx
Francesco
  • March 16, 2018
frsisani wrote:
HY
thx
Francesco
Consider posting a small sample dataset here.
jdh
Forum|alt.badge.img+28
  • March 16, 2018
I use a topologyBuilder, test the Nodes for those that only have one element in the _node_angle{} list, and then FeatureMerger with the Edges based on the absolute value of the fme_arc_id (node) and the _edge_id (edge). Those that have a match are dangle, those that have multiple matches are isolated.
  • March 16, 2018
Hi
I create the WB that identify the dangle geometry but now I have to go into the loop to iterate the WB several time in order to remove the dangle geo generated AFTER FIRST RUN
can you help me ?
thx
Francesco
falsegeo.fmw
  • March 16, 2018
Hi @frsisani, you will have to create a custom transformer to perform the process for removing dangles recursively. I posted a solution before: Looping According to Spatial Data
And this is a new version which implements your approach. The FeatureMerger routes the lines (Requestor) to the "Loop to Input port" if a dangle node (Supplier) exists, to the Output port (i.e. finishes the looping) otherwise
See these links to learn more about how to create a custom transformer for looping.
  • March 19, 2018
Hy Takashi
Thx for your help
I tried to understand the "logic" of loop probably I'm very close to the solution but... not completely.
Attached my WB can you please have a look ?
Thx
Francesco
false-geo.zip
  • March 19, 2018
frsisani wrote:
Hy Takashi
Thx for your help
Thx
Francesco
false-geo.zip
Please read carefully the documentations I linked in the previous post. Especially this one is important:
Looping with a Blocking Transformer
Since the looping process contains some blocking transformers (Matcher, SpatialFilter, FeatureMerger [Edited] Sampler is not a blocking transformer), you will have to export the custom transformer (Insert Mode: Linked Always), make sure some parameters to enable loop with blocking transformer, and then use it in the main workspace as a linked custom transformer.
I tested your custom transformer after exporting, and it seems to work as expected.
