Custom Transformer: FeatureCrossJoiner
  • Nov 29, 2024 6:19 AM UTC
  • 5 replies
  • 238 views
bwn
Forum|alt.badge.img+26
One thing wish FeatureJoiner had was a CROSS JOIN / Cartesian Product mode to create every permutation of Feature Set A vs Feature Set B  (Eg.  When creating To-From Lines between every possible Origin Point and every possible Destination Point).
Custom Transfomer FeatureCrossJoiner is not anything really radical in how it gets FeatureJoiner to do this by creating a temporary dummy Cross Join attribute, but perhaps simplifies the process for some users.
https://hub.safe.com/publishers/bwn/transformers/featurecrossjoiner
Forum|alt.badge.img+54
  • Nov 29, 2024 9:57 AM UTC
It might be nice to adapt so that you could choose between a full cross join, i.e permutations, or combinations
Create a table with all possible pairings of numeric values from input table. | Community
  • Nov 29, 2024 10:22 AM UTC
You can use the InlineQuerier to do cross joins out of the box:
  • Nov 29, 2024 10:39 AM UTC
The FeatureJoiner method gives you a few more options for handling geometries. It’s also needed if you’ve self imposed a rule of no python or inlinequeriers when doing advent of code :-)
  • Nov 29, 2024 10:47 AM UTC
It’s difficult to argue against self-imposed restrictions ;-)
bwn
  • Nov 29, 2024 11:44 AM UTC
Yup, and similarly use InlineQuerier for exactly that. 😉   I get the impression though that in the Community that there is a mix of just not knowing about InlineQuerier for alternative SQL methods, or they find writing the SQL daunting, or maybe be lazy like me and just want a workspace shortcut to just quickly pop 1 x Transformer onto the workspace, connect 2 x connectors and not have to write anything else 😉
Plus as ​@ebygomm notes, FeatureJoiner has thing like automatically putting the Schema back into Bulk Mode, it can be faster in a lot of circumstances too if the upstream Features are in Bulk Mode and can Aggregate the Left/Right Geometry.  But yes, I use both for Cross Joins depending on circumstances.
Again, nothing earth-shattering:just something to be able to avoid a couple of AttributeCreators and an AttributeRemover, and an alternative to point users to with the occasional Cross Join questions that come up.
