Custom format - Parameters were not exposed
  • Aug 13, 2022 8:02 AM UTC
  • 69 views
ranga_tolapi
Forum|alt.badge.img+11
By referring to the article Creating a Custom Format and section Using the Custom Format Wizard, I have created a custom format along with few (Published) user parameters.
imageHowever, when consumed the custom format via Workspace Resources of a new FME workbench, user parameters those were created in the custom format were not appearing.
Add Reader as ResourceNavigator
Did I miss anything here? I was expected to see the user parameters that I have created in custom format.
Enclosed the .FDS that I have created.
FME 2022.1.0.0 (20220704 - Build 22618 - WIN64)
@david_r​  @Mark Stoakes​  @debbiatsafe​  @chrisatsafe​
ranga_tolapi
  • Aug 25, 2022 5:32 AM UTC
All FME gurus over there, awaiting for your valuable response.
jpvo
  • Sep 22, 2023 11:38 AM UTC
Hello, I'm on FME 2022.2 but having similar issue with custom format. I'm trying to make a custom format out of an Oracle base reader but I can't igure out how to get is working properly. Parameters do not seem to be passed along as expected. Does custom format support database readers properly?
Thanks
.JP
