creating sampling hexagons
  • Jun 14, 2018 5:48 PM UTC
  • 5 replies
  • 139 views
arthy
Forum|alt.badge.img+8
Hello,
Is there a way to create sampling hexagon using fme (and python caller) that would cover a study area?
Basically, the idea is to create a mesh of sample hexagons and ensure that that all regions within the study area are represented by the sampling results as you can see in this post?
Thanks
Best answer by larry
I just published the HexagonSampler on the FME Hub.
  • Jun 14, 2018 7:51 PM UTC
arthy
  • Jun 19, 2018 3:46 PM UTC
Thanks @larry,
I sligthly modified it but the main idea was there.
Thanks again
  • Jun 19, 2018 4:02 PM UTC
Thanks @larry,
Thanks again
I you want to share your modifications, I can update the transformer on the hub to share with others.
arthy
  • Jun 19, 2018 4:21 PM UTC
I passed the input and the output of the arcstroker trough a spatial filter so that only hexagons that intersects the input will come out.
fikusas
Forum|alt.badge.img+5
  • Dec 4, 2019 12:41 PM UTC
When passing calculated value from attribute, results are incorrect. How can I pass Hexagon Side Lenth value from the attribute?
