Creating new points/nodes along a line that bends.
  • Oct 18, 2024 10:52 AM UTC
  • 130 views
jaosakkeimr
Observer
Forum|alt.badge.img+3
So, in the context of pipelines we run camera inspections registering different damages and features along the pipeline. We have registered pipelines by ID in a larger gis database. I already have a script running that reads the information and returns all the registerd freatures in the camera inspections and draws it in a arcgis. The issue is that sometimes the lines have bends even with the same ID. making it hard to create new points at the specified distance.
So what i need is something that creates a point at a specific length from the starting point ID, that takes into account the geometric changes of the line.
in the example picture under, i want to draw a point at the POI. I have the distance(70m) from start. But there does not seem to be obvious functionality for this in FME. Any ideas?
dustin
Forum|alt.badge.img+36
  • Oct 18, 2024 11:00 AM UTC
There is a custom transformer in FME Hub that should do this for you. https://hub.safe.com/publishers/safe-lab/transformers/distancemarker
jaosakkeimr
Observer
  • Observer
  • Oct 18, 2024 11:23 AM UTC
Will this make it possible to draw multiple symbols along the same line?
dustin
  • Oct 18, 2024 11:26 AM UTC
FME doesn’t symbolize features per se, but yes, it should create multiple points along the line from which you could symbolize in the platform you are working in.
