Creating new LRS From and To measures using Geometry Length
  • Jun 12, 2019 12:16 AM UTC
  • 63 views
trevorm
Forum|alt.badge.img+3
Hello, I have an legacy LRS where the line work is Spatial but the From and To are typed in manually.
I wish to correct the FromKM and ToKM with correct Line measurements, and make the field 3 decimal KM.
I have built the following workbench:
* filter out one Roadname for sample
* Extract Geometry
* Get the @abs(FromKM - ToKM) * 1000 for meters
* Get Geometry length
* measure difference
I need to be able to use the Geometry Length to create a new from/to KM
@trevorm Your sample FFS file didn't come through with the template .since it's not a source dataset in your workspace you'd have to explicitly select it when you create the FME template. Could you upload it again? Thanks.
