creating kml file from sketchup model
  • Jun 2, 2017 2:38 PM UTC
  • 85 views
mitra
Forum|alt.badge.img+4
Hi all
I have a sketchup model where I need to place one tree at certain xyz points. The thing is I already have the point where the tree need to be placed as shape file and a model of a tree in sketchup.
Has anyone tried replacing a point data set with a sketchup model and then exporting the whole thing as a kml file.
Any ideas would be appreciated
mygis
Forum|alt.badge.img+14
  • Jun 2, 2017 3:44 PM UTC
Hi @mitra
Since you a;ready have the point in Shapefile, why don't you just convert that point into KML without going through the conversion into skp format?
Cheers.
Lyes
mitra
  • Jun 2, 2017 9:07 PM UTC
Thanks. But I need to replaced the point with sketchup. In other words I want to get x and y from point and give it to sketchup. Then the sketchup of tree would be placed in the point position
