Creating Grid for specified no. of features
  • November 28, 2014
  • 72 views
How can we create a Grid using FME workbench such that each grid consist only 100 features in it?
nilsur
  • November 28, 2014
Hi Max,
Try
2DGridCreator (>100 cells in total) => Sampler(100 first)
Nils
gio
Forum|alt.badge.img+15
  • November 28, 2014
100 features in the grid (of undefinde size) or a 100cell grid (10x10;2x50 etc.)?
First would be more complex if possible at all depending on the inputdata. ;)
pratap
Forum|alt.badge.img+12
  • November 29, 2014
If the grid size doesnot matter then you can use counter and filter the features by 1 to 100 & 101 to 200 so on.
Later use the boundsextractor,BoundingBoxReplacer and dissolver for each set.
rid will be ready for each 100 features...
Pratap
  • February 20, 2015
Hi Pratap,
Thank you for your valuable response.
Well im quite now to the FME environement and as per your solution i did tried grouping the features using list builder and then using boundsextractor, bounding box replacer too but didnt got the desired solution. Can you share a visual representation of how it should be used so as to do it in a right way :)
