I was wondering that if there is a workflow for FME that is able to produce a 3d Graph ( Bar/ line) from an inputed text file. I am thinking for the output to use 3D pdf to have better user intraction for panning and zooming at the same time some filters also.
Is this possible and is there a better way to see 3D output other than 3D pdf.
Thank you,
Ishan
