Creating and enclosed polygon of the point data. Hi, I have a pole data connected to houses. I wanted to create an enclosed polygon with the pole and all its corresponding demand points. Can some one help. Attached is the requirement
  • Jul 20, 2022 8:18 AM UTC
  • 8 replies
  • 97 views
Best answer by geomancer
You can replace the HullAccumulator with a VoronoiDiagrammer (no special settings), followed by a Dissolver grouping by pole ID. This will fill your whole plane.
Poles_and_points_alternative_ending
danilo_fme
Forum|alt.badge.img+58
  • Jul 20, 2022 10:39 AM UTC
Hi @krishnamohan​
Please, try to use the transformer HullReplacer.
Thanks in Advance,
Danilo
I want to enclose them, but this is actually connecting all the points
Krishna
danilo_fme
  • Jul 20, 2022 10:55 AM UTC
Krishna
Please, share us your data.
Please find the data.
geomancer
Forum|alt.badge.img+71
  • Jul 20, 2022 1:31 PM UTC
Something like this...
  1. Copy the IDs of the poles to the lines using PointOnAreOverlayer, merging the attributes
  2. Copy the attributes of the lines to the points, using another PointOnAreaOverlayer, merging the attributes
  3. Calculate the convex hull of the points and the poles, group by pole ID
Note: I renamed the attributes of the poles and the points, as they had the same attribute name.
Poles_and_points
Poles_and_points
Many thanks for the same. But it is not serving my purpose. I need to create polygons like this in the below screenshot
geomancer
  • Jul 20, 2022 2:17 PM UTC
Thank you
