Creating a sample based on a length attribute
  • Mar 1, 2019 12:42 PM UTC
  • 8 replies
  • 120 views
Hi there,
I'd like to find out if there is a way to generate a sample of my data based on a measurement instead of a count?
The Sampler transformer seems to do the calculations based on counts of features, but what I need is, for example, say I have 1000 kilometers of road geometry, and I want a random sample of 50 km.
Is this possible?
Thanks in advance,
  • Mar 1, 2019 1:05 PM UTC
Hi @robbie_botha, if I understood your requirement correctly, the RandomNumberGenerator and the Snipper might help you.
Create a random number between 0 and 950 (= 1000 - 50), then snip out a 50 length part from the random number's position on the line.
  • Mar 1, 2019 1:25 PM UTC
If you don't want to alter (snip) the geometry you can use an AttributeCreator and a Tester to only let the first total 50 km of road segments to pass through, e.g.
You can then e.g. test for _total_length < 50000 in the Tester.
Hi @takashi
I think what I failed to mention is that it is not a single line feature. It is an entire network of several roads, which are in total 1000km. I want to sample a few random roads that have a total combined length of 50km.
My apologies, I should have added it to the original post. It is important that I keep the geometry in the state it is now, so I'm not sure snipping will work.
  • Mar 1, 2019 2:18 PM UTC
If you want to randomize the data, you could insert a Sampler before the AttributeCreator, set to randomize sampling.
gio
Forum|alt.badge.img+15
  • Mar 1, 2019 4:05 PM UTC
@robbie_botha
Count the total roadfeatures and use a rng to create sample selections.
@round(@rand*total_featureCount, 0).
Then use this to select features, add their length till 50 is reached.
If you need a sample of some minimal size then create sets that sum to 50. (Query the superset for your minimal count set. You probably need to use TCL or some lesser snake to do it. And don't output the superset.)
Common misunderstanding: if you read a dataset and mutilate it in some fme process... the original dataset is still were it was, in its original state. Till you overwrite it!
gio
  • Mar 1, 2019 4:21 PM UTC
Here is a TCl powerset version I made. (with the help of math sites of course..)
This one is iterative. (I failed to get the recursive version with inner summing/counting to work and di nto pursue it any further)
Stuff it in a TCL-Caller.
This one counts objects. You can easily adapt it to sum lengths.
change {[ladd $pset_cnt] <= 100} to do that.
@Takashi can probably do that in a sec..
proc test {} {
##objectenlijst ophalen
set list items{}
##fme lists inlezen naar tcl lists
for {set i 0} {[FME_AttributeExists Object_list{$i}.OBJECTID]} {incr i} {
lappend items_id [FME_GetAttribute Object_list{$i}.OBJECTID]}
for {set i 0} {[FME_AttributeExists Object_list{$i}.count]} {incr i} {
lappend items_cnt [FME_GetAttribute Object_list{$i}.count]}
set Subsets_out [lindex [powersetb $items_id $items_cnt] 0]
set Subsets_count [lindex [powersetb $items_id $items_cnt] 1]
set Subsets_itemcount [lindex [powersetb $items_id $items_cnt] 2]
##Aan criteria valdoane Subsetlijst naar fme list schrijven
for {set i 0} {$i<[llength $Subsets_out]} {incr i} {
FME_SetAttribute Subset_list{$i}.Subset [lindex $Subsets_out $i]}
FME_SetAttribute Subset_list{$i}.count [lindex $Subsets_count $i]}
FME_SetAttribute Subset_list{$i}.itemcount [lindex $Subsets_itemcount $i]}
##subsets in aparte lists stoppen??
##powerset
proc powersetb {set count} {
set res {}
set res_cnt {}
set res_itemcount {}
for {set i 0} {$i < 2**[llength $set]} {incr i} {
set pos -1
set pset {}
set pset_cnt {}
set pset_itemcount {}
foreach el $set {
if {$i & 1<<[incr pos]} {
lappend pset $el
lappend pset_cnt [lindex $count [lsearch $set $el]]
if {[ladd $pset_cnt] <= 100} {
lappend res $pset
lappend res_cnt $pset_cnt
##aantal elementen per subset tellen
lappend res_itemcount [expr {[lsearch $pset [lrange $pset end end]] + 1}]
##alle items van de uitvoerlist uitvoeren in een samengestelde list
return [list $res $res_cnt $res_itemcount]
proc ladd {l} {
set total 0
foreach nxt $l {
incr total $nxt
return $total
jdh
Forum|alt.badge.img+41
  • Mar 1, 2019 4:41 PM UTC
Hi @takashi
Do you want truly random roads, which most likely end up with several road segments that are completely unconnected to one another, or do you want a random 'region of connected roads'?
  • Jan 13, 2020 10:09 AM UTC
Hi there! I am looking for something similar, but with parcels and acres. See my question here:
https://knowledge.safe.com/questions/105643/add-until-a-certain-value-is-reached.html
I need to know if there is a way to randomly select parcels that together have a combined area of 13 000 ha
Thank you!
