Creating a new feature class in a GEODATABASE from an ARCGISFEATURES source fails
  • Jul 15, 2025 8:09 PM UTC
  • 112 views
davidlee
Forum|alt.badge.img+9
This issue seems to appear again in FME 2025.1!
crystalwang
Forum|alt.badge.img+31
Hi ​@davidlee,
Apologies for the late response. I’m sorry to hear that you’re running into issues with creating a new feature class. If you can please submit a ticket so that our team can look into this further, that would be great!
When submitting your ticket, please provide the following (if possible):
  • The .log file from the failed translation with debug enabled.
    • Please go to Tools > FME Options > Translation > and enable Log Debug. Re-run your workspace with log debug enabled and send us back the resulting .log file.
  • A sample workspace with some sample data to reproduce the error on our end.
    • Please be sure to include any required data or custom transformers needed. If, possible please send this as a template (.fmwt).
We’ll be able to better help you with a little more context surrounding the error. Thank you for your patience!
