I am using FME Workbench 2022.1 along with ArcGIS Pro 3.0. I recently noted an issue when copying data from an AGOL MapService to a local GDB - if the feature class does not exist in the GDB, the Workbench will fail, only reporting "Error running the translation" and no further details in the log file. However, if I create a feature class in the GDB, even without any attributes, and change the writer to "Drop and Create" from "Create If Needed," the Workbench runs. Any Ideas?
Log File attached
Best answer by nampreetatsafe
Hi @lance, I'm sorry you encountered this issue! I managed to reproduce the problem using an ArcGIS Pro 3.0 license with FME 2022.1 as well. I found a similar report in our system (FMEENGINE-73958) and have referenced this thread to our internal ticket. We'll try informing you here if there are any updates. In the meantime, please try the following workaround:
In the Navigator > Workspace Parameters > Scripting > set Python Compatibility = Esri ArcGIS Python 3.9+
enter some python in the Startup Python Script (Startup Python Script = pass).
I did a quick test with ArcGIS Pro 3.2 and FME 2025.1.0, but I wasn't able to reproduce the error on my end. If possible, please send your workspace along with some sample data, or a screenshot of your workspace and how you set up the writer. Please also send your log file so I can take a closer look at the error.
