Creating a HTML report that updates as the workbench completes.
  • Feb 10, 2022 10:45 AM UTC
  • 5 replies
  • 112 views
bjudes
Forum|alt.badge.img+10
I am running a workbench using the workspace runner. This workbench runs 12 times with a different area running through it each time. It takes roughly 3 days to complete all stages.
I want to create a HTML report so I can get a simple percentage complete of this process. I have created a process whereby the sum of features passed through is counted in the statisticscalculator and this is then used to derive what percentage complete I am. However, due to the fact that I am using the runner and each area runs through on it's own. The statisticscalculator calculates that only 1 has through each time. Therefore I always get an update saying I am only 8% (1/12) complete, even though I may be farther.
Would there be another way of achieving this? Hope this makes sense and thanks for any help.
B
Forum|alt.badge.img+63
Perhaps, but it kinda depends on how your workspace is set up and how many features you are processing. You could use a Sampler and FeatureWriter to split off one in every x features and then have the FeatureWriter write that out to an HTML file, overwriting the previous one.
bjudes
  • Feb 10, 2022 11:21 AM UTC
Thanks,
The number of features would vary greatly for each of the 12 instances. Also, the HTMLReportGenerator seems to hold the features so I can only get a final percentage rather than an update throughout the workbench?
bjudes
  • Feb 10, 2022 11:42 AM UTC
Do you know if there is a way I can get a feature to run first due to an attribute. For example, could I get the first feature to run through be attribute value 1, second is 2 and so on?
Thanks
Can you share a screenshot of your workspace and some background information?
mark2atsafe
Forum|alt.badge.img+59
Thanks
Yes, you could use a Sorter transformer to do that.
