Creating a boundary of .las files
  • November 20, 2015
  • 6 replies
  • 226 views
How to create boundary of individual .Las files?
pratap
Forum|alt.badge.img+11
  • November 20, 2015
I don't have experience in working with las file but I know that it is a point file.
So just a try, have you tried "PointConnector"
Pratap
  • November 20, 2015
pratap wrote:
Pratap
I tried but not working
pratap
  • November 20, 2015
Does the data have serial number (i.e:1,2,3)?
Is it possible to send sample data.
Pratap
Forum|alt.badge.img+50
If you use a PointCloudCoercer to transform the point cloud to individual points you can then use a HullAccumulator to create a concave hull of those points. It's probably advisable to thin the point cloud first though (PointCloudThinner)
Hi!
How many LAS files do you have?
I would recommend using BoundsExtractor because it's easy to use. Here's a simple example below in which I take one .las file as input and create a extent polygon in a geojson format:
If you like you can also use a bufferer to produce a buffer polygon with 0 buffer and merge all those buffers into one single polygon.
In the following link I found a lot of transformers you can use on Point Clouds.
https://knowledge.safe.com/articles/1138/transform...
roland.martin
Forum|alt.badge.img+9
simonsundell wrote:
Hi!
The BoundsExtractor only works if your LAS files are square and in a straight north-south and east-west line - otherwise the HullAccumulator suggested by @redgeographics is the way to go!
