Create polygon from point
  • May 20, 2016 10:53 AM UTC
  • 6 replies
  • 577 views
ingalla
Forum|alt.badge.img+10
fmelizard
Forum|alt.badge.img+22
  • May 22, 2016 5:27 PM UTC
mygis
Forum|alt.badge.img+14
  • May 24, 2016 6:32 AM UTC
Hi @ingalla, I have created a transformer and put it in the store/hub, open your FME 2016.1 and search for RectangleCreator. You will need to set the width, height and the rotation (if required). Hope this works for you.
Fantastic Tool!! Congratulations ^^
  • Mar 30, 2017 8:52 AM UTC
Hi @ingalla, what kind of polygon do you need to create from point(s)? e.g.
  • Bufferer: creates a buffer area for each point.
  • HullAccumulator: creates a convex or concave hull that contains given multiple points.
  • VoronoiDiagrammer: creates Voronoi domains for each point.
Other?
erik_jan
Forum|alt.badge.img+26
  • Mar 30, 2017 2:15 PM UTC
I would use the Bufferer transformer.
And use the "Square buffer" mode to create rectangles. Using the "Round buffer" mode creates circles.
  • Jan 24, 2022 5:38 AM UTC
very useful, thank you
