Create points at 1 m intervals along a line and assign a sequential ID from 2000
  • Nov 1, 2026 11:37 PM UTC
  • 66 views
galigis
Forum|alt.badge.img+22
Hi all,
I’m trying to create points at 1 m intervals along a line, with a sequential ID starting at 2000.
As shown in the screenshot below, I need the sequence to start at the south-western end of the line with ID 2000, then increase by 1 for every metre as it follows the line towards the north-east and then back towards the north-west.
So essentially:
  • Start of line = ID 2000
  • Next point, 1 m along the line = 2001
  • Next point = 2002
  • Continue incrementing by 1 following the actual direction/path of the line
I have tried using the DistanceChopper from the FME Hub to split the line into 1 m segments. I then calculate the X/Y coordinates of the start/end points, use a VertexCreator, and finally a Sorter based on the X coordinate.
This works up to the location marked X in my screenshot. However, because the line curves back on itself in the X direction, sorting by X no longer represents the correct order along the line.
What I really need is a way of ordering the generated points by their distance/position along the original line, rather than by their X or Y coordinates, and then assigning the sequential IDs starting from 2000.
Is there a better approach or transformer for achieving this?
Below the current workflow
Any suggestions would be very welcome. Thanks!
Best answer by ctredinnick
MeasureGenerator, starting from 2000
IterativeSnipper or RepetitiveSnipper to cut into 1m long lines
Snipper to take the starting vertex of those lines
MeasureExtractor to get the distance along the line back out to an attribute.
ctredinnick
  • Nov 2, 2026 6:04 AM UTC
galigis
  • Nov 2, 2026 8:11 PM UTC
Thanks - spot on! :)
DanAtSafe
Forum|alt.badge.img+23
  • Nov 9, 2026 10:16 PM UTC
Hi ​@galigis There’s also the DistanceMarker custom transformer which I just updated from FME 2019 to 2026.
danilo_fme
Forum|alt.badge.img+58
  • Nov 17, 2026 9:20 AM UTC
Great ​@DanAtSafe
