Create new line from measure
  • Oct 30, 2017 4:52 PM UTC
  • 92 views
I have polyline with polyline_id with start and end measure (ex : 0 and 100). And another descriptive information (without geometry) with start and end measure (ex. 50 and 75) and the polyline_id.
I did featureMerger and then snipper with measure value.
But I got the whole polyline (0 start and 100 end ) but I want polyline with (50 and 75)
There is something wrong. Any idea how can I get it.
Thanks
Best answer by erik_jan
I think you have the right approach.
The image shows the Snipper approach:
The result is a line from measure 25 to 75.
erik_jan
Forum|alt.badge.img+26
  • Oct 30, 2017 5:09 PM UTC
  • Oct 30, 2017 6:12 PM UTC
thanks, it is only working with distance value (but I'm not sure if one can use distance value to get lines from measure to measure). If I use measure value I got the whole polylines.
erik_jan
  • Oct 30, 2017 6:19 PM UTC
IN my example I used the Snipper, using Measure (value).
I have attached the sample workspace.
snipper.fmw
  • Oct 31, 2017 12:38 AM UTC
thanks. It was strange. If I use the polylines from gdb, then measure setter or generator is working. If I use Postgis source, it does not.
