Create new attribute with value set as test filter output port name
  • Jan 29, 2025 3:53 PM UTC
  • 213 views
mcannalea
Participant
I’ve got a test filter with about 12 different output ports. My goal is to unfilter all of these but have an attribute of “test result” and the value set to which output port the feature filtered through. Is there a way to expose the output port name? I know I could add attribute creators after each port or set one with a conditional statement but was hoping there was an easier way.
j.botterill
Forum|alt.badge.img+69
  • Jan 30, 2025 1:02 AM UTC
Hi there, have you signed up to the FME academy? The following exercise takes you through using a TestFilter versus AttributeManager new output, using conditions set in an attributevalue
https://academy.safe.com/use-conditional-values/155538
