Create minimum bounding triangle?
  • Dec 19, 2018 9:40 PM UTC
  • 5 replies
  • 113 views
gcarmich
Participant
Is it possible to create minimum bounding triangles for groups of points using FME desktop?
jdh
Forum|alt.badge.img+41
  • Dec 19, 2018 10:29 PM UTC
Not natively.
A linear-time algorithm is described in https://link.springer.com/article/10.1007/s40314-014-0198-8 and the corresponding c++ implementation is available at https://github.com/ovidiuparvu/minimal-area-triangle
OpenCV also has an implementation of the minimumEnclosingTriangle based on O'Rourke's algorithm.
https://docs.opencv.org/master/d3/dc0/group__imgproc__shape.html#ga1513e72f6bbdfc370563664f71e0542f
gcarmich
Participant
  • Participant
  • Dec 20, 2018 6:50 PM UTC
Not natively.
Can I easily integrate these implementation into a Transform for use directly in FME?
jdh
  • Dec 20, 2018 7:00 PM UTC
If you know a bit of python and install OpenCV it should be relatively straightforward to extract the geometry of the features and convert them to the point array needed for the MEC algorithm using the pythonCaller.
https://knowledge.safe.com/articles/841/install-python-modules-into-fme.html
fmelizard
Forum|alt.badge.img+22
  • Dec 22, 2018 1:08 AM UTC
Out of curiosity, what is the application of this? Seems like an interesting thing we could eventually support natively.
gcarmich
Participant
  • Participant
  • Dec 22, 2018 1:22 AM UTC
It could be helpful in aligning wireless field measurement back to their point of origin when propagated by a directional antenna.
