Create Line Buffer to receive Polygon with z-coordinates
  • Nov 1, 2021 8:30 AM UTC
  • 14 replies
  • 190 views
aharport
Forum|alt.badge.img+4
291 / 5000
Übersetzungsergebnisse
I'm looking for a transformer with which I can create a buffer around a line. This buffer should have a defined width. The line has z-coordinates.
At the end I would like to continue using the buffer polygon that was created and the polygon should receive the z-coordinates of the line.
itsmatt
Forum|alt.badge.img+48
  • Nov 1, 2021 8:50 AM UTC
What's the use case here? Do you have something you could use to drape a normal 2D polygon over? For example, Road line > buffer to polygon, drape polygon over terrain? Or is that workflow not an option?
aharport
  • Nov 1, 2021 9:14 AM UTC
These are protective tubes (lines), which are now to be displayed as protective tube polygons with a fixed width. The z-coordinates should be retained.
itsmatt
  • Nov 1, 2021 9:22 AM UTC
Ahh the bufferer here should work to create pipes/tubes. There is an option for a 'solid' buffer type.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/bufferer.htm?highlight=Solid
aharport
  • Nov 1, 2021 9:55 AM UTC
Thanks, but I don't need any geometrical solids. I only need a 2D polygon area with the z-coordinates of the line ends.
Forum|alt.badge.img+54
  • Nov 1, 2021 10:16 AM UTC
So you're hoping to end up with something like this?
How complex are your lines?
aharport
  • Nov 1, 2021 10:24 AM UTC
Exactly
itsmatt
  • Nov 1, 2021 10:31 AM UTC
Here's something which should work for polylines but also single line geometries
It seems overly complicated, but the idea is to just find the line which is perpendicular to the line/pipe sections and then use an offsetter + extruder to create a new 3D surface. You can then get back to the polygon.
itsmatt
  • Nov 1, 2021 10:32 AM UTC
imagePerhaps a little over complicated but should be pretty robust
aharport
  • Nov 1, 2021 12:28 PM UTC
Thank you. Unfortunately, only polylines with support points can be transformed. Polygons cannot be created from simple lines with only a start and end point.
itsmatt
  • Nov 1, 2021 12:34 PM UTC
Can you explain a little more what you mean? do you mean this process doesn't give you what you want? Can you try and modify it to make it work for your data?
aharport
  • Nov 1, 2021 12:46 PM UTC
I'm sorry, I don't know how to describe it better. Lines without vertices are rejected by the Chopper Transformer and cannot be written. My source data is in dgn format.
aharport
  • Nov 1, 2021 12:49 PM UTC
Should I send you a sample file?
itsmatt
  • Nov 1, 2021 1:01 PM UTC
Ahh then you should just be able to remove the Chopper - this was just put in in case they we not simple lines. The process should still work. You can also then remove the aggregator at the end.
aharport
  • Nov 1, 2021 1:41 PM UTC
I think it works now. I connected the Untouched output from the Chopper Transformer to the GeomtryExtractor. I have to test it thoroughly again tomorrow. Thanks very much :-)
