Create column with coordinate in decimal degree
  • June 13, 2016
  • 12 replies
  • 133 views
Hello Dear FME users,
I have *.txt file. Inside this file I have columns with coordinate in metres (EPSG 28409). I need create columns with coordinate in decimal degree.
How I can realise it FME?
Thanks in advanse,
regards,
Anzhelika
  • June 13, 2016
Look at the CsmapAttributeReprojector.
You'll probably want to select "PULKOVO_to_WGS84" in the Transformation option.
amolparande
you can use AttributeReprojector
you can use AttributeReprojector as well
  • June 14, 2016
That's true, but the AttributeReprojector is missing the option to explicitely set the geographic transformation, which is necessary for some reprojections if you want to preserve accuray.
It's the same thing as with the Reprojector vs the CsMapReprojector.
  • June 15, 2016
@david_r, @amolparande Thanks a lot for your replay and aswers,
As I understand this transformers can project data, but I need to create new colums with new coordinates. in attached file you can see example of *.txt data and FME workspace, in txt I have columns C-Nav Easting, C-Nav Northing and I need output data with columns C-Nav Latitude, C-Nav Longititude with coordinates in decimal degree.
Could you please check my data and give your advise?
  • June 15, 2016
I can't see any attachments, but it's really simple: Just use an AttributeCreator to copy the Easting/Northing values to a couple of new attributes containing the Latitude/Longitude values and then reproject those.
  • June 15, 2016
  • June 15, 2016
Thanks for the workspace. Try replacing the AttributeReprojector with a CsmapAttributeReprojector and configure it something like this:
Hope this helps.
  • June 15, 2016
@david_r I can't open this image or attachment. Could you please sent it for a.kamza@geoken.com
  • June 15, 2016
I haven't posted any attachments. Does the image not show in your browser?
I'm not sure what more you need.
  • June 15, 2016
My broweser can't open it.
  • June 15, 2016
Can you see it now?
  • June 16, 2016
thanks. Will check
