Create column names from column values.
  • Oct 26, 2015 2:12 PM UTC
  • 8 replies
  • 593 views
Hello,
guess this question has been asked here many times, however I still struggle with finding a good answer.
Basically what is happening: this is a table that shows records all possible values of all possible attributes, from all possible objects. However I need to create a table, where column names will be values from the column 'attribute', where each row will be singular object. Real table has much more columns, this is just an extract.
Resulting table should have one row per 'object_id', attributes created from 'attribute' column and the attributes created should be filled with values from 'value' column. There are going to be a lot of attributes created, not each of those objects has all of those attributes.
Any help is really appreciated.
Radek
  • Oct 26, 2015 2:32 PM UTC
Hi
The easiest is to first create a temporary workspace to read all possible values of the 'attribute' column and use a DuplicateRemover and then manually create the output table based on those. In a second workspace, read your input data and use an AttributeRenamer to rename the value columns, then use an Aggregator (Keep input attributes=Yes, group by=object_id) to assemble your features before writing them.
A more complex solution could use dynamich schemas, see https://knowledge.safe.com/articles/Samples_and_Demos/Dynamic-Workflow-Tutorial-Destination-Schema-is-Derived-from-List-Attributes
David
  • Oct 26, 2015 2:52 PM UTC
Hello and thanks for a fast reply.
I am trying to implement this on FME cloud, and quite possibly in a single workspace, therefore i have no idea if any of your suggestions will work.
I have been trying attributepivoter, to no success.
  • Oct 26, 2015 2:56 PM UTC
Just to clarify: I am trying to write a workspace that takes tables from a schema stored in a postgresql database, joins several of those tables to style data with geometry. This table I have sent in this example serves as a way to add and style data with geometry, that are stored elsewhere.
mark2atsafe
Forum|alt.badge.img+59
Easiest way is to use an AttributeCreator. The attribute to create is the value of the attribute field, and the value of that attribute will be the contents of the value field.
Like this:
tono
Forum|alt.badge.img+13
  • Apr 4, 2017 1:39 PM UTC
Like this:
I am trying the same thing in FME Desktop 2016 build 16674 and I do not manage to get values as attributes names with this method. Does it still work for 2016 version of FME Desktop?
  • Apr 5, 2017 12:51 AM UTC
Hi @tono, yes, it still works for FME 2016 and 2017. Note that the new attribute name created with this method won't be shown automatically on the Workbench GUI. You can expose the new name with the AttributeExposer if necessary.
johnnygalambos
I just ran into this as well. Using this approach also seems to wipe out the feature. A inspector showing a single feature before an attribute creator set up like this will show a table with values for all attributes. A inspector placed after this attribute creator will show an empty table. This is with build 16716.
Update: Actually sorry I take this back. The attribute creator does appear to work--it's the FME Data Inspector Table View that appears to not like the output of this type of attribute creator. My feature is still there with the new attribute--the table view is just empty.
tim_wood
Forum|alt.badge.img+8
  • Aug 1, 2018 12:42 PM UTC
Like this:
This was useful for me. I'm reading in various CSVs, each of which has logged a different validation error for the same dataset. Using the AttributeCreator solution above, I can turn the fme_basename into an attribute name and assign it a value of "Fail". The AttributeExposer then makes these attribute names available in the Workspace (slightly annoying they don't appear automatically). I then use an Aggregator (on the unique ID for each record) and NullAttributeMapper (to fill in the <missing> values) to combine the various CSVs into a single output table listing the features that failed validation, and which tests they failed. Thanks everyone.
