Create attribute columns based on attribute row values
  • Feb 19, 2014 6:42 PM UTC
  • 264 views
I have this type of data set with a number of observations with values of town, type and number - and a possibility of observing more of the same type in the same town.
Town; Type; Number
Town 1; Type A; 4
Town 1; Type A; 2
Town 1; Type B; 6
Town 2; Type A; 7
Town 2; Type B; 11
Town 3; Type C; 21
Town 3; Type A; 32
Town 3; Type B; 3
Town 3; Type B; 4
etc.
How would I get my source data set to look like this? Town; Type A; Type B; Type C; Sum Town 1; 6; 6; 0; 12
Town 2; 7; 11; 21; 39
Town 3; 32; 7; 0; 39
I have tried using the new AttributePivot on Town and Type, but it would give me this result really.
  • Feb 19, 2014 11:53 PM UTC
The BulkAttributeRenamer can be used effectively.
1) BulkAttributeRenamer
Rename: Selected Attributes
Seleted Attributes: Number
Action: Regular Expression Replace
Text To Fine: .*
String: Type  (Attribute Value)
2) AttributeExposer
Attributes to Expose: Type A, Type B, Type C
3) Aggregator
Group By: Town
Mode: Attributes Only
Keep Input Attributes: No
Attributes to Sum: Type A, Type B, Type C
4) AttributeCreator
Sum = @Value(Type A)+@Value(Type B)+@Value(Type c)
Takashi
  • Feb 21, 2014 5:38 AM UTC
I found that attribute value can be specified as new attribute name in the AttributeCreator of FME 2014. If you are using FME 2014, can use the new functionality.
1) AttributeCreator
@Value(Type) = Number  (Set value of "Type" to new attribute name)
Sum = Number
2) AttributeExposer
3) Aggregator
Group By: Town
Attributes to Sum: Sum, Type A, Type B, Type C
  • Feb 21, 2014 6:34 AM UTC
Sorry, that's not new. FME 2012, 2013 also can do that. You can type "@Value(Type)" directly in Attribute Name column of the AttributeCreator.
