Good day,
I have a line with a center point on it. I would like to create a polygon around this line that should intersect the last and first vertex of the line. The longer side should be 2m long (as long as the line) and parallel to the line. The shorter side should be perpendicular to the line, 1.6m long and intersecting the line halfway. How can I achieve this ?
