Create an attribute for intersected polygons
  • Oct 2, 2021 10:38 AM UTC
  • 52 views
Hi, I have two polygon layers (Layer 1 and Layer 2). Layer 2 contains a subset of Layer 1 polygons i.e. one polygon of Layer 1 can contain 1 to n polygons of Layer 2 (Image). Each polygon in Layer 2 needs to be uniquely identified by using two attributes: ID of Layer 1 and pol which represents the number of Layer 2 polygons within one Layer 1 polygon (image). How to create a pol attribute?
danilo_fme
Forum|alt.badge.img+58
  • Oct 3, 2021 11:20 PM UTC
Hi @moset221​
In your case, I created a Workspace using the transformer Counter.
Inside the configuration was detected the option GroupBY ( your example the ID ) and the Count Start begin 1.
Counter
Thanks in Advance,
Danilo
