Create a visible edge from a 3D Object (FBX) out to KML
  • Sep 10, 2021 6:18 AM UTC
  • 105 views
I have created a 3D model which shows a 'radiation zone' I created this from REVIT > FBX which will ultimately become a KML/KMZ. I have looked at Styling the edges within the Authoring software ie Revit, but that's a non starter.
Is there any way that FME can 'style' the edges of this 3D model on writing to KML ?
Many Thanks, please see my other question regarding the rotation of this object.
RadiationZone
Forum|alt.badge.img+63
Have you tried the KMLStyler?
  • Sep 10, 2021 9:36 AM UTC
Redgeographics, which was my one and only port of call to date, could not find anything there with my limited knowledge and trialling that changed anything about the model whatsoever. Seems to be more for placemarks.
I haven't done much with 3D objects in KML, but I know the KMLStyler works on extruded polygons. Apparently that's not the same 😕
